Mike_G
- Jun 1, 2000
- Mike
Hi all,
Last week I picked up my first HDTV. The problem I have now is the same I had when I moved to S-Video years ago - not enough inputs on the receivers. I currently use a Pioneer VSX-608 which has NO comp. inputs.
These are the inputs I need:
DVD
HDTV Receiver
PS2
XBox
Gamecube
Possible HTPC connection (not counting this one)
That's 5. Five inputs. Most receivers I've seen have 2. No switch boxes with Component AND digital audio input. I currently use a Sony mechanical switch for the video and a RS digital audio switch for the optical, but it's very annoying and I can do a max of 4 with that.
This is for the upstairs which means that unlike the downstairs, I can't put a Denon 5800 in there. I'm looking at the sub-$500 range.
Any help on this?
Thanks.
Mike
DVD
HDTV Receiver
PS2
XBox
Gamecube
Any help on this?
Thanks.
Mike
