Considering CSW Newton T300 6.1 Speaker System: Comments?
Discussion in 'Archived Threads 2001-2004' started by Thad_C, Feb 21, 2002.
  1. Thad_C
    Thad_C Agent
    Feb 20, 2002
    38
    I've been lurking in this forum for a while, searching for ideas for an HT system around $2000 (excluding receiver). I'm considering the Cambridge Soundworks Newton Theater system w/ T300 towers, but have not heard them--I'll just return them if I don't like them (around $1700 w/ discount at hifi.com). In fact, I'm planning to check out a few alternatives this weekend (perhaps Paradigm, if my budget will permit). Does anyone have any comments on CSW system? I've also checked out Axiom, but I haven't heard them (and probably won't have the opportunity, as I live in Chicago). Any thoughts would be appreciated.
    OT: I'll also need a receiver, and CSW is offering the Marantz SR7200, which, based on HTF user comments, has had some problems in the past. Should I be concerned?
    Thanks in advance for your comments! This forum is incredible for those of us who are Newbies.
    Thad
  2. Thad_C
    Thad_C Agent
    Feb 20, 2002
    38
    I forgot to mention-- I'm considering, specifically, the Paradigm Phantom or Legends. Thanks!
  3. Dave Vaughn
    Dave Vaughn Stunt Coordinator
    Oct 8, 2001
    186
    Thad,
    I am a big fan (and owner) of cambridge soundworks speakers, but I would not buy the T300 towers. The mid range sticks on them and the built in subs are "boomy". If you are set on Towers, then I would go with their original Tower speakers. They have a very good soundstage and when mixed with a good sub (SVS of course), they cover all of the bases. I have their centerstage center speaker and their Newton S300 surrounds (4 of them) with an Onkyo 989 receiver and SVS 20-39 PC sub.
    My second favorite speaker of theirs is the MC300. These actually have a very good sound to them and the price is right. I have heard these with their small sub (the one that is $999) and they sounded awesome. I can only imagine how they would sound with a SVS. The nice thing about these speakers, is you can have three identical speakers across the front for a seamless soundstage.
    Just my .02 worth.
    Good luck in your choice
    Dave
  4. Tony Genovese
    Tony Genovese Supporting Actor
    Oct 5, 2000
    811
    An alternative would be 3 MC500's up front. These are basically T500's without the built in sub and they sound unbelievable. You can pick them up on sale for $250 each. Coupled with S300's in the rear and an SVS sub and you would have an absolutely amazing system for around $2,000 complete.
  5. Matt Barrett
    Matt Barrett Extra
    Dec 10, 2001
    24
    I agree, I have 3 MC300's across the front, S300's in the back and a 4th MC300 for rear center.
    They are awesome sounding speakers; everyone who hears them can’t believe they are made by CSW.
    I also have a pair of P1000 subs up front. They might not move the air like SVS can, but they do a decent job.
    I'm sure a system built with MC500's would be insane
  6. Dave Vaughn
    Oct 8, 2001
    186
    Matt,
    The P1000 is a very good sounding sub. If I couldn't have a SVS, that would be my next choice. The only knock on it is that it is a little pricey for the performance. One SVS 20-39 has about the same output as 2 of the P1000's, and the 20-39 goes a little deeper. Other than that, that is a great setup. How big of room do you have and what receiver are you driving them with?
  7. Matt Barrett
    Matt Barrett Extra
    Dec 10, 2001
    24
    Dave,
    I have my system in a 14' x 19' room
    Onkyo 797
    Panasonic RP-56
    Sony KP-53HS30
    Monster HTS3500
    I still have a bunch of things to try (I love to tweak, as we all do ;-)
    I have the MC300’s wall mounted but I can feel/hear what I think is too much vibration being transmitted to the wall, so I want to try placing some Sorbothane pads under the feet and around the screw they hang from to decouple them from the wall.
    I need a BFD for the subs, I have some hotspots that are annoying me and the single parametric EQ on the controllers isn’t enough, I need like 3 more filters to get it flat.
    Still not sure which mode I like best for the S300’s but I keep them, in bipole most of the time.
  8. ThomasL
    ThomasL Supporting Actor
    Mar 13, 2001
    963
    Thad, I have the CSW Newton series speakers as well. Instead of MC300s across the entire front, one can also look at the bookshelf series. I had to have front speakers that were
