Connections to old TV
Discussion in 'Home Theater Projects' started by Pam_S, Jan 21, 2004.
  1. Pam_S
    Pam_S Auditioning
    Sep 26, 2002
    14
    Hi all!
    In my bedroom I have an old TV with only one connection. I also have a Directv box. I currently have a VCR connected. I would also like to connect a DVD, but can't figure out how since the TV only has one connection.
    Any ideas?
    Pam
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    When you say "One connection", do you mean like one set of RCA composite jacks-- or one connection like RF (the screw type connector with audio and video in one)?
    You can get a cheap A/V selector from radioshack... and then if you need to convert the signal to RF, you can also get a RF modulator.
    -Vince
  3. Pam_S
    Pam_S Auditioning
    Sep 26, 2002
    14
    All the TV has is an RF connector.
  4. JeffPhill
    JeffPhill Agent
    Dec 7, 2003
    28
    Does your vcr have an aux. input (red, white, and yellow)? If so, connect to it.
  5. Vince Maskeeper
    Jan 18, 1999
    6,499
    Of course if you use a VCR as the converter, macrovision will kick in and the picture on DVD will darken/lighten every 30 seconds.
    RF modulator and a switcher will be your solution.
  6. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
    As Vince said, get an RF Modulator. Here's one from Radio Shack for 30 bucks:
    http://www.radioshack.com/product.as...5Fid=15%2D1214
    The one I purchased last year 'auto senses' when the DVD player is turned on and switches inputs to DVD by itself. When the DVD player is turned off, it reverts back to Cable input.
  7. JeffPhill
    JeffPhill Agent
    Dec 7, 2003
    28
    Sorry, I didn't know about the macrovision problem.
  8. Bill Will
    Bill Will Screenwriter
    Dec 26, 2001
    1,282
    First before you buy a Modulator try plugging the DVD player into your VCR because on some VCR's they will pass the picture to your TV without the "Macrovision" kicking in because it will only kick in when you press the Record button on the VCR which is to prevent you from copying copyrighted DVD's.
