Brad Gable
Grip
- Nov 4, 2002
Hi All,
My new home theater system was just delivered so now I am in the process of hooking everything up. I wanted to explain how I planned to hook it up to make sure it is the proper way and that I am getting the most out of the system.
First I will list the equipment then the proposed connections.
Pioneer Elite PRO-730 RPTV
Yamaha RX-Z1 Receiver
Yamaha C-920 DVD
Kenwood Multi Disk CD J1070
B&W Front Center and Surround Speakers.
No VCR or Satellite at this time however I am currently looking into getting a satellite receiver with TIVO.
Now for the connections:
I am planning to use the receiver to do the switching of all signals if possible.
DVD
Connect the component video out to the component dvd in on the the receiver and the optical audio out the the digital dvd in on the receiver.
CD (Analog only output. It is an older model.)
Connect the Analog output on from the cd player to the analog input of the receiver.
TV
Connect the component output from the receiver to the component input (1) on the tv. Then connect the Audio output of the tv to the audio input on the receiver. I was also planning to run an S-Video cable from the receiver monitor out to the S-Video input (2) on the TV. This will allow for on screen control of the receiver. Then of course I will attach the coax cable to antenna A for the TV signal.
So now the questions. First does this seem logical and is it the best way to hook everything up. Second, should I worry about connecting the remote in/out cable between the units. I am not really sure what this will buy me if anything. Also I should mention that the receiver came with a RAV-2000 remote so I am planning to control it all with the one remote.
Thanks for taking the time to respond as I appreciate any and all advice.
Brad
Yamaha C-920 DVD
DVD
TV
Brad
