Connection options
Discussion in 'Home Theater Projects' started by JamesGL, Aug 2, 2004.
  1. JamesGL
    JamesGL Stunt Coordinator
    Dec 17, 2003
    147
    I have a regular digi cable box in my den.
    For connection, which is best, RF cable to cable box, then L/R audio to reciever, then RF to TV.
    OR
    RF cable to cable box, then L/R audio to reciever, then composite video to TV
    I can't tell the difference using the eyeball method but I assume one has to be better.
    All cables are generic cheapo radio shack types since this is just in my den.
  2. JamesGL
    Dec 17, 2003
    147
    Forgot to mention that the cable box has no S-vid or Comp Vid connections. Thanks.
  3. Cornelius
    Cornelius Stunt Coordinator
    Feb 24, 2004
    117
    You probably won't be able to tell much of a difference, but the second option should result in a better picture.
    CJ
