connection of bass shakers..help
Discussion in 'Archived Threads 2001-2004' started by dan scorpio, Jan 19, 2003.
  1. dan scorpio
    dan scorpio Stunt Coordinator
    Jan 19, 2003
    56
    i just bought 2 new pro bass shakers 50 watts rms..i also am thinking of buying the bass plate amp from parts exress
    it is the one that is 120 watts.... i know that i have to connect my sub out from my pioneer 5.1 receiver to the mono in to the base plate amp, no problem but how do i connect the speaker wire from the shakers to the amp?
    all the amp has is high out and high in...do i plug it in to the high out of the amp? and will that do it? because in the parts exress info it says in order for the high out to work you must connect the high in?
    i am confused
    also if i connect to the high out from the amp, will it send the low frequency to the bass shakers?
    thanks...........
  2. Matthew-K
    Matthew-K Stunt Coordinator
    May 24, 2002
    95
    I have the same setup as you. If they are wired in series, connect the negative wire from the shakers to the black lead on the back of the plate amp. The same with the positive from the shakers to the red lead on the back of the plate amp.
