Connecting VGA to RGB/HV???
Discussion in 'Archived Threads 2001-2004' started by William Ward, Jun 28, 2001.
  1. William Ward
    William Ward Supporting Actor
    Mar 1, 2000
    701
    I'm planning on getting a Mitsubishi 55807 with the RGB/HV inputs. I'm also interested in the RCA DTC100 HD receiver. This has a VGA output similar to computers. How would I go about connecting these two??? DO they make some kind of VGA to RBG/HV converter similar to the VGA to Component???
    William
    Go Bucs!!
    MyDVDs
  2. Matt_R
    Matt_R Stunt Coordinator
    Dec 9, 2000
    77
    Yes, RCA makes their own transcoder - I believe it's around $120 and you can find it at Best Buy or Circuit City.
    OR, you can get breakout cables... MUCH cheaper, although I'm not familiar with them, so maybe someone else will step in...
  3. William Ward
    Mar 1, 2000
    701
    What exactly is a "breakout cable" or do you know??
    William
    Go Bucs!!
    MyDVDs
  4. Kevin Coleman
    Kevin Coleman Second Unit
    Jul 3, 1999
    495
    William,
    You can get VGA to RGBHV breakout cables at most computer stores. That is where I bought mine and it works great. It has a VGA connector on one end and your RGB+HV on the other end. You can usually find them for about 15 bucks.
    Kevin C. [​IMG]
  5. Abdul Jalib
    Abdul Jalib Stunt Coordinator
    Dec 27, 2000
    175
    You can also get VGA breakout cables athttp://www.digitalconnection.comClick to subscribe to Philips_HDTV discussion group
  6. AllenD
    AllenD Second Unit
    Feb 20, 2000
    412
    William,
    Not only do you not need a transcoder but you can't use it for VGA to RGBHV to connect the DTC-100 to your 55807. As mentioned, all you'll need is a Male VGA to RGBHV breakout cable.
