Danklin26
- Aug 31, 2006
- Noel
Hi, I'm hooking up a JVC dvd/vcr combination player to a new Sharp flat panel tv. I also have a HDTV cable box that will be hooked up soon. My question is, how do i hook up the vcr through all this? I was told to connect the vcr to the tv with standard rca cables after going through the cable box with a coax. Is this correct?
Also, the dvd/vcr seems to not want to output through s-video for the dvd player. Even after doing the "trick" in the manual to get it in s-video mode (holding down stop and then pressing the channel up button) the s-video will not output if the round coax is connected for vcr use. DVD is currently plaing through the coax also which I know isnt the best picture. Any help is appreciated. Sorry if this is confusing.
