Jason Walstrom
- May 6, 2003
Is it better to run a y-splitter type rca cable to each of the two subs from the lfe out on the reciever or run one cable to one of the subs and run the other from the output of the first sub to the second. Also, if I am running a sub in the front between the center and the right tower and the second in the rear left corner, should the Sub settings be the same. as in gain and crossover?
