Connecting Sub at rear of room
Discussion in 'Home Theater Projects' started by chrisGA, Apr 26, 2006.
  1. chrisGA
    chrisGA Auditioning
    Feb 14, 2006
    11
    Folks, here is my issue. I'm looking to put a 2nd sub at the back of my HT. Any ideas where to get about 30' of rca cable for the run from my amp to my sub...and would there be a substantial loss over a run that long ?
  2. Phil A
    Phil A Producer
    Oct 1, 2000
    3,171
    38
    Central FL
    Phil
    If that's what you want, you could also get a cable with 'F' connectors and get 'F' to RCA adapters at each end. Lots of places to get 30 ft. cables - e.g. Blue Jeans and others. Length should be no big problem.
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I echo what Phill said.
    I bought a 25' hunk of pre-terminated CATV coax from radio shack. Then I added 2 "F-to-RCA-Female" adaptors and that gave me a long RCA cable to run to my sub. Cost me all of $12 a few years ago.
    but - The "Sub Humans" (Tom and Ron of SVS Subwoofers) have often suggested NOT putting multiple subs around the room. They often interact in a complex pattern so it's normal in your seat, but the person sitting next to you gets the sound doubled, and the person on the other side gets the 2 sounds cancled out.
    They recommend putting the subs on top of each other or right next to each other. This way the 2 subs create the same sound waves in sync and give the room louder low-frequency without the interaction problem.
    Hope this helps.
