FrankC
- Feb 26, 2001
Gang:
I have a quick newbie question about connecting speakers to the Marantz SR-8000. I just bought a used DH Labs cable with spade connectors to hook up my PSB Stratus(i)s.
The cable doesn't connect to the receiver as I expected. There's a circular black plastic jacket at the base of the receiver's binding post which protrudes about a 1/2" from the receiver's back plate. It has two holes (at the 1 and 7 o'clock positions), presumably to accomodate bare wire. The jacket prevents me from attaching the spade lugs as I would expect, namely flush with the back panel of the receiver.
Can I remove that jacket? Or am I just doing something wrong? Worst case, I suppose I could reterminate with bananas, but I thought this was a standard 5-way binding post.
Thanks in advance for your advice,
--f
--f
