Anish
- Jul 26, 2002
Hi guys,
So I picked it up my Denon 3802 and just the other day I bought a set of cables. I got the AR Master series and I also got a set of RCA cheapo cables. I am thinking about doing a comparison. I hope you can help me out here.
But I am having some troubles connecting the cables. Firstly, do I need doubles of everything, if I want to connect the cables to the receiver? I don't think I quite understand how to make the TV pick up the audio from the receiver (I have the video connected through component). I have a satellite receiver and a DVD player, both connecting directly to the TV through component. So how do I make any and all audio go through the Denon 3802? Right now I only have 2 front speakers, 2 rear speakers and a sub.
Also, if you are familiar with the Anthony Gallo speakers, I have speaker cables that come with banana connectors at the end. However I am not able to connect it to the post at the back of the Due's or Micros. If you have seen the posts at the back of these speakers, you will know what I am talking about. So how do I get around this? Do I have to buy speakers that are just wire coming out the ends so that I can bend it around the posts and then tighten it?
Hope you guys can spare a few minutes to help me out here.
Just in case it helps, my TV is the Panasonic 47WX52 and my DVD player is the Panasonic DVD-RP82.
Thanks.
Thanks.
