Connecting preamp to integrated amp
Discussion in 'AV Receivers' started by RobWil, Apr 19, 2005.
  1. RobWil
    RobWil Supporting Actor
    Mar 17, 2003
    733
    I want to connect a tube preamp to my solid state integrated. The only component I'm currently connecting to the integrated is a CD player. The integrated has a preamp-out, for connecting an external amp, but no main-in. The integrated does have tape input and record out jacks though. I believe I've read where you can connect the preamp to the tape loop. Is this correct and, if so, how exactly is this done. Thanks in advance!
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Well, you just go into the tape/record input.
    It sort of works, but the dang volume on the integrated is usually still in the chain. I have not had any good luck doing this. It works but just not real well.
