Connecting PC to TV
Discussion in 'Home Theater Projects' started by Marlin Liew, Aug 11, 2004.
  1. Marlin Liew
    Marlin Liew Auditioning
    Jul 17, 2004
    2
    I went and ordered a VGA to component video cable thinking that I could just connect my video card to my TV and everything would work. Then I found out that this is not the case since the signals are not compatible.
    Is there any software/tweaked drivers that I can use to convert the signal coming out from the VGA output on my video card to make it sync to the TV? I have a GeForce2 MX. Or would doing this require additional hardware?
    Thanks.
  2. Cornelius
    Cornelius Stunt Coordinator
    Feb 24, 2004
    117
    I don't think there is any way of doing this with software. I think that you need a video card with either component video out (not RGB) or DVI, depending on what your TV can handle.
    CJ
