Connecting Marantz receiver to Amp
Discussion in 'AV Receivers' started by grantG, Apr 5, 2005.
  1. grantG
    grantG Agent
    Feb 15, 2005
    32
    Does anyone know how/if I can connect a Marantz 7400 receiver to a B&K amp so that the amp will turn on when the receiver does? Is this a DC trigger?
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Yes that is a DC trigger and the 7400 has the capability.
  3. grantG
    grantG Agent
    Feb 15, 2005
    32
    John, I noticed that its an RCA jack on the amp but a smaller plug on the receiver? Does this sound correct?
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Hmmmm not sure on that one. You may just need an adapter, or maybe you can use the Marantz remote control feature, which should use an RCA - that's how I trigger my Marantz amps (but of course, then they are Marantz).
    On the off chance, have you checked to see if the B&K has signal sensing capability or is operated by DC trigger only?
    Do you already have the 7400?
  5. grantG
    grantG Agent
    Feb 15, 2005
    32
    Yes, I have the 7400 already.
    Not sure about the signal sensing? What is that?
  6. John S
    John S Producer
    Nov 4, 2003
    5,460
    Some amps will monitor for signal and turn on if they detect one.
  7. grantG
    grantG Agent
    Feb 15, 2005
    32
    I saw where Radio Shack has a cable with a mini-plug on one end and an RCA plug on the other. Maybe I will give that a try.
