COnnecting an optical cable?
Discussion in 'Archived Threads 2001-2004' started by Christian Speights, Apr 19, 2002.
  1. Christian Speights
    Christian Speights Stunt Coordinator
    Sep 14, 1999
    102
    I have finally gotten to the point where I would like to use my second available digital connection on my receiver (got a cd player with digital outs).
    Problem is, connecting the optical cables seems harder than it should be. I am pretty sure I had them aligned right and everything...and I tried to force it in there pretty good. I just did not want to try TOO hard and end up busting something on my player or my receiver.
    It's a Monster cable so I wouldn't expect any kind of gross defect that would prohibit me from connecting it.
    I just don't get optical cables I guess. Never had to use one until now.
    Any tips for the dumb guy?
    (I did pull out that protective little do-hickey thingamabob already)
    Thanks in advance.
    Christian
  2. John Welch
    John Welch Stunt Coordinator
    Mar 11, 1999
    67
    Did you remove the plastic cover from the end of the optical cable?
  3. Stacey
    Stacey Stunt Coordinator
    Feb 10, 2002
    174
    Hmmm...when you look at the end of the cable it's in a "D" kind of shape so make sure your aligning it up properly with your amp. On mine, I feel a little "click" when the cable is in all the way and I don't need to force it whatsoever.
    Hope that helps.
  4. Christian Speights
    Sep 14, 1999
    102
    Thanks John and Stacey...it was the protective piece on the cable.
    I don't feel stupid or anything. Honest. :b
    I guess RTFM applies to me in this case.
