Montalvo
- Dec 21, 2008
- Bob
I have a six-year-old Panasonic plasma TV (model TH-50PHD5UY) and want to connect a newly purchased Nintendo Wii to it. And I want it to work both as a TV and as a Wii without having to switch cables, since the TV nestles snugly into a recess in the wall making it hard to get to the connections on the back.
The TV's video signal (TiVo) comes in via the composite (Video In) plug and another satellite box and a VCR also come in via this plug. I have a Crestron home automation system that does the switching. The DVD player comes in through the component plug (Pr/Cr/R, Pb/Cb/B and Y/G).
When I saw that I had an S-video port, I bought a Wii cable that had both an S-video, composite (yellow) cable and white and red audio cables. I connected the white and red cables to a separate set of speakers and the S-video to the plasma's S-video port (not connecting the composite cable) and the Wii worked great. But when I then turned on the plasma to watch TV...nothing! I switched the plasma's "input" setting from "Video" to "Component" to "PC" but that had no effect. Even unplugging the Wii cable from the Wii box didn't allow me to get a TV signal. Only when I unplugged the S-video from the plasma did I regain a TV video signal.
Finally I bought an S-video switch, figuring I could connect to the Wii and then throw the switch to a port with no connection to disconnect it. But apparently the plasma recognizes that an S-video cable is plugged in and defaults to that even if it's not connected to a device. No go!
Now I'm thinking it might be best to connect the plasma's composite plug to a switch, allowing me to flip the switch when I use the Wii and then switch it back when watching TiVo/DirecTV/VCR. Does that make sense? I'm running out of both patience and money, buying switches and cables.
Thanks for any suggestions you can offer.
