Connecting a vcr and dvd with only 1 tv input
Discussion in 'Archived Threads 2001-2004' started by Lisa Menin, Dec 23, 2002.
  1. Lisa Menin
    Lisa Menin Agent
    Jan 1, 1999
    49
    My friend has an older tv with only one set of inputs. He has a vcr already connected to it and is buying a separate dvd player. Is there a way to connect both units to the same input - perhaps via a switcher box? If so, will the switcher box cause ghosting?
    Thanks in advance...
    Lisa
  2. Carl Johnson
    Carl Johnson Cinematographer
    May 6, 1999
    2,259
    25
    1,610
    Carl III
    You can buy A-B switch boxes pretty much anywhere that sells electronics. Picture quality will not be significantly degraded by the switch.
  3. Ernest
    Ernest Supporting Actor
    Dec 21, 1998
    707
    85
    610
    DVD players only have Audio / Video conncetions, SVideo, composite and component, not coaxial cable. You can't use an A/B switch. Because of the macrovision copyguard you shouldn't run the DVD player into the VCR to use the VCR as an audio / video switch. You need to buy an audio / video switcher that has inputs and outputs for SVideo and Composite video. Radio Schack sells those type devices.
