connecting a powered subwoofer to basic home stereo (1 Viewer)
bwilliams48
Bobby
Is this possible? Do you use the line in function above the audio rca cable spots? Cause their isn't very many options, it only had enough speaker connections for the 2 it came with. I would like to connect a powered subwoofer cause it has basically no base, its a 300 watt system. I want to make sure it is possible before i spend the money on it but i don't want to have to get a new system, i just want more bass from the one i got.
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
Yes, as long as the sub has High Level Inputs and Outputs. You connect the left/right speaker wires to the High Level Inputs on the sub. You then connect your left/right speakers to the High Level Outputs on the sub. Then you can use the subs crossover.
TheThrillisgone
