BrettisMckinney
- Aug 25, 2002
Ive been playing with HT for ages and though it might be an incredibly stupid question its something I havnt had to have any experience with. Basically what Im wondering is if you want to use 96kz for 2 channel audio, can that only be achievable over analogue? I ask this as I am using a DD sound card in my PC that you can select the output format..I can choose between 48kz or 96kz and the card is connected through a Digital Coax cable. When i select 96kz i dont get any sound though.
Ive just put an audio cd into my dvd player running through the same amp and instead of using optical ive used 2 RCA's. In the dvd setup i selected 96kz and now it plays. Do I make any sense??
