I just recently had someone build me a DIY midq Tempest (about 2x2) with a 380w Rythmik amp but I'm having trouble figuring out the frequency sweep tone with avia. I have a Sony Da4es and for the time being all the crossovers are at 80 but when the frequency starts at 200hz or whatever the volume goes up if I turn up the gain on the sub itself. Why is there sound coming out of the sub if it shouldn't kick in till 80 hz? The crossover on the sub is set to its highest setting but I thought the receiver would take care of that, should I also set the crossover on the sub to 80, I didn't think that was necessary but maybe i'm mistaken.
There is also a gap in the sound from about 50-30 or so, is this a placement issue? I am using a radio shack meter and the needle goes all over the place but I have heard that they don't measure low frequencies very well...is that the case?
Can subs be placed anywhere or do they do best when they are up front with the front speakers? What placement generally gives the flattest response? When you guys put your sub in a corner do you wedge it evenly in there or is just in the general area of the corner i.e a foot or two along either wall?
Room size 11x15, is this square enough to be worried about standing waves and is there anyway to combat them.
Thanks for the help
Thanks for the help
