Frank joe
- May 28, 2002
hi , all i know this has been covered many times and i have read alot of threads. i confused on my sub's placement . i have 2 subs a f-1800vx velodyne which is foward firing and a kilpsch ksw12 which is doward firing. here is my question if i stack them like alot of people are saying i should does it matter that they don't fire the same way ( one foward and one downard)? also if i am correct in saying that they are suppose to go on the same front end of the room with the main and center speakers will this cause a problem with my 60'' rear projection tv. i know the velo book says its not shielded and neither is the klipsch. i dont think the 60'' mitsubishi is either. i presently have the 12'' on the front wall with the tv and the 18 on the left wall in the middle of the room ( but it sits next to my leather sectional at the end so the couch does rock) . my room demsions are 12Width x 25Lenth .and 8' acoustial drop celing. oh yea my floor is cement with just commerical capret no padding its glued down. 1 more thing front part of my room is an L shape so ther is no right corner only left side. also when i hook up the subs do i only use the left line in or do i use a y connector and go into both left and right lines on input for subs . thanks all i know its benn covered but i still don't get it fully sorry frank
