Tim_R_H
- Feb 12, 2002
I am looking at upgrading to the Dennon 3802 receiver or an equivelant Onkyo/Yamaha. I was looking to add a rear center channel (6.1 channels). The receivers I am looking at have 7.1 channels and if I understand correctly the 7.1 channels are front L/C/R, surround L/R, rear L/R and sub. My confusion seems to be that I have heard 7.1 as I stated above but have also heard it stated that both the 6th and 7th channels are rear center speakers. The diagram below shows the way I prewired my HT area with the upper case O's representing current speaker placement (not including my sub). All wireing was done to plates in the ceiling. I wired to the locations I did with the assumption that recievers may eventually support an 8.1 format Front L/C/R, side L/R and rear L/C/R . My current surrounds are about 2 1/2 feet behind the couch, are surrounds suppose to be directly to the side or was my placement ok? I'm thinking that with 6.1 even though my placement for my surrounds may be off I can still get by. With 7.1 though I'm not sure I can use my current wiring due to the side speaker wiring being about 2 1/2 ft in front of the couch. Can someone please confirm the 7.1 layout for me and if my wiring for the side speakers is unusable since they are in front of the viewer. Thanks!
16' deep x 14' wide
|..O.........O.........O..|
|..o....................o....
|.........Couch..............
|..O.........o.........O.....
16' deep x 14' wide
