Confused about how I'm going to be wiring this.
Discussion in 'Beginners, General Questions' started by Noah Gottula, Dec 8, 2005.
  1. Noah Gottula
    Noah Gottula Stunt Coordinator
    Jan 20, 2003
    96
    I'm buying a JVC 56" HD-ILA
    http://www.jvc.com/product.jsp?model...hId=114&page=2
    I also plan on getting an Xbox 360, OPPO DVD player, and I have the comcast cable DVR box.
    The Xbox 360 uses HD component cables, the OPPO DVI and comcast box uses DVI or components.
    How will I plug all of this in to take advantage of the best picture quality? As far as I know the TV has one HDMI input, and two HD components.
    Is using a DVI/HDMI connector for the OPPO, and using the components for my comcast DVR my only option? And will I notice any difference having to use components instead of DVI on the comcast box?
    Let me know what you all think.
  2. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    Probably not, but before you invest in a DVI switch box, you can experiment by changing your inputs around and decide for yourself.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Seems like you have enough inputs....
    Component Video switching is decently cheap. You can even generally find a complete surround audio system that can switch it and give you more HD Component inputs as well for under $300.00
  4. Noah Gottula
    Jan 20, 2003
    96
    It would have to be a pretty big picture difference for me to invest $300 on a switch.
    What about receivers? Would this be a good way to go? Getting a receiver that can take all sorts of inputs and put them on one DVI/HDMI to the TV.
  5. PatrickJB
    PatrickJB Extra
    Oct 26, 2005
    19
    I just wasted 10 minutes typing up an reply with links just to get swatted by the system and the damn link policy.
    Sorry Noah, I'll try again later if I have the patience.
  6. Noah Gottula
    Jan 20, 2003
    96
    Thanks anyway Patrick, any help is greatly appreciated.
  7. PatrickJB
    PatrickJB Extra
    Oct 26, 2005
    19
    Long story short...
    This receiver is under $300 and is often recomended as a
    low cost choice around here:
    >>(hope this works)circuitcity.com/ssm/Panasonic-Surround-Sound-Receiver-SA-XR55-/sem/rpsm/oid/131941/catOid/-12884/rpem/ccd/productDetail.do>amazon.com/gp/product/B0002H6M0S/qid=1134593940/sr=8-10/ref=sr_8_xs_ap_i1_xgl23/104-8543512-3680748?n=507846&s=electronics&v=glance
  8. PatrickJB
    PatrickJB Extra
    Oct 26, 2005
    19
    ...or go to google and search for:
    Athena 15345 Point 5 MKII
    and
    Panasonic SA-XR55
  9. joseph westcott
    joseph westcott Second Unit
    Oct 24, 2005
    355
    The Oppo is a waste of money if you do not use the DVI output.
    Component output on the Oppo is limited to 480i only.
  10. PatrickJB
    PatrickJB Extra
    Oct 26, 2005
    19
    "Oppo"
    What is that?
    ...EDIT... Nevermind, it's the DVD player : ) ...EDIT...
