Stefan A
- May 27, 2001
I was at a friends house the other day listening to his new HT setup. His setup is much different than mine - although we both have good equipment. One of the main differences is that he has a 250 watt 2 channel amp hooked up to his pre-outs for the mains. All I have is a Yamaha RX-V596 (100 watts per channel). So, we watched the depth charge scene from U-571. His wasn't necessarily louder - just more powerful. In my setup, I hear plenty of bass. In his, you get the bass plus a stronger explosion sound (this is real hard to descibe in words). It was as if I have been missing part of the sound track all this time. I know there are other variables involved, but I think the extra amp is making the biggest difference.
So, of course now I want to know if I can re-create that sound if I add an amp to my setup. So I go to tweeter to talk to a salesman about my options. First he tells me that the 596 that I have just won't send "a good signal" to an external amp - so it may not sound too good.
So I am thinking, why the hell do I have preouts on my receiver if it is not worth using?
Then he goes on to tell me that a 2 channel amp for my mains will be a bad combo for a HT setup. He says it will be great for music, but for HT it will make everything uneven. That it will drown out my other channels.
So I am thinking that it is more about the quality of sound than volume. I could use the test tones to adjust the volume of all my speakers compared to each other.
In the end, he was trying to steer me toward a Yamaha rx-v2200 instead of a power amp. I realize that the 2200 is going to be a better receiver than what I have, but they are both 100 watts per channel.
Do you think this salesman was steering me the right way? Will a 2 channel amp combined with my 596 be a bad choice? Is the 2200 going to make my setup sound completely different? As different as an amp would?
