Configuring linksys router to remote desktop
Discussion in 'Computers' started by Andrew_A_Paul, Sep 17, 2004.
  1. As per my other post for gamespy, i am trying to fully congigure my new router. How is the best way to configure the router and most secure way to do this without just opening the 3389 port? Can i make this more secure? Thanks guys.
  2. Glenn_P
    Glenn_P Auditioning
    Jan 11, 2000
    6
    Hi, to get remote desktop you have to open the port. Or use another software that uses other ports.
    But the remote desktop is safe enough
    Of course there are more safe ways to do this like VPN, but the user level is high and maybe costs also.
    Just keep your pc up to date with patches and updates.
  3. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    the port is only open while its being used, just route that port too your computer and you will be fine.
  4. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    you can hack Remote desktop to use a different port, and then when you type your address into the remote machine just use that port instead...
    I used to do this on my machine, doesn't necessarily make it MORE secure, just a little harder to find.
    -V
  5. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    you can also look into using VNC software which is, for the most part, the same as remote desktop. Something like ultr@VNC works well and you can adjust what port it uses.
  6. Thanks guys.
