Fred Seger
- Aug 13, 2000
This is kinda of a combo question.
1) When you look at X-max specs are they always one-way?
2) When you look at cone-excursion results in Lspcad are they referring to the one way Xmax or total movement which is always greater than 2x-Xmax( I think)
Example
I'm modeling a 6.5" driver that has a 3.15mm Xmax according the spec. Do I need to keep the cone excursion under 3.15mm or 6.3 mm?
Example
