Concerning burn-in
Discussion in 'Archived Threads 2001-2004' started by DaleI, Jan 29, 2002.
  1. DaleI
    DaleI Stunt Coordinator
    Jun 5, 2001
    128
    For those who do watch a lot of dvds (widescreen/anamorphic ones), should you worry about burn-in of your TV (Wega, in my case) if you have brightness/contrast properly calibrated?
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Yes you should worry.
    After you determine proper calibration by any method suggested to you, lower the contrast to about 30% for projection TV and about 45% for direct view if the contrast was previously higher. Then re-calibrate as best as possible. Now you don't have to worry about how much letterbox movie viewing you do but you should still not play video games a lot unless you lower the contrast even more, and sighificantly.
    Video hints:
    Proper calibration will vary depending on the level of room lighting.
  3. DaleI
    Jun 5, 2001
    128
    My contrast is already set properly thanks to Ve and Avia.
