ThomasL
- Mar 13, 2001
I've ripped a number of my CDs using EAC + Lame (using the recommended defaults for LAME encoding) and the quality of the MP3s when played off the hard drive is excellent. I burned some of them onto a CD-RW and that went fine with all data verified as being burned correctly. Here comes the but - when I play them directly off the CD-RW, there are small pop/clicks every 20-30 seconds. They seem random and as best I can tell, has something to do with the speed of reading the data off of the disc. For example, if it makes a click sound and I immediately "rewind" it, it works fine with no clicks. This would make sense since the data has been cached and no disc access is required. I get this behavior with both Winamp and Windows Media Player. Finally, if I copy then off of the CD-RW into a temp directory and play them, they play fine with no clicks/pop sounds.
So, does anyone know the exact reason for this and is there a workaround or fix for it? It seems a pain to recopy everything off of the CD-RW whenever you want to play it. I'm making these so I can listen to my CDs at work.
thanks,
--tom
thanks,
--tom
