Daniel_S
- Feb 2, 2004
Hi everybody,
At the moment I'm looking at my options for true HiFi speakers for my computer, as I am just not satisfied with MM speakers (big fan of music, but I am only 15 so I don't have much experience with higher quality speakers so bear with me). Basically, I am going to get either a M-Audio Audiophile or a Terratec DMX 6fire LT. Then I am going to hook it up to a surround reciever. From there the reciever will power some tower speakers most likely, like some axioms or rockets. I have looked at each of these cards, and am a little confused about how I would connect everything.
Both cards have analog stereo outputs, the terratec has optical digital out (TOS link) and the audiophile has spdif. Now, is spdif the same as the coaxial inputs on a reciever? And would I be able to use the optical digital out to connect to the receiver? Also, I see 6 analog inputs on most recievers, while these soundcards only have stereo analog outputs (as well as a few CD changers I have seen...EDIT: haha, of course, music doesn't use 5.1 encoding, that's for dvds...lol). So would I be forced to use digital if I wanted surround to work correctly? (As you can tell by now I'm a bit of a n00b ) Or has that been the way it's always been?
Lastly, would all of this "work"? Would there be any forseeable problems I could run into?
If anybody has done this I would GREATLY appreciate any advice and some direction. Links to guides and how-to's are also welcomed!
TIA
TIA
