Computer -> 5.1 or 2.1 + hi-fi speakers??
Discussion in 'Beginners, General Questions' started by Ned*C, Feb 10, 2005.
  1. Ned*C
    Ned*C Auditioning
    Feb 9, 2005
    2
    Hey there people, I'm new.
    I am looking to add a 5.1 system + hi-fi speakers for games/music at my computer. Currently I take a line out of the back of computer that goes into 2 aux/Minidisc in hi-fi. How would I add this to it... ebuyer.com - search "49368" I know its 6.1, but hey....
    If this isnt possible, how about (ebuyer search "74746") 2.1 + hi-fi = 5.1 coming from computer. How would I connect them both into computer?
    I dont have much money yet. When I get a summer job, Im getting a massive widescreen [​IMG]
    I hope this makes sence.
    Cheers.
  2. Ned*C
    Ned*C Auditioning
    Feb 9, 2005
    2
    Ok no replies... is there normally one cable coming from sub that you'd plug into computer (or dvd player i assume)?
    But I kinda need two imputs. I could get a small mixer, but that's expensive condsidering the 2.1 I'm looking at.
    Any thoughts at all? [​IMG]
  3. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    normally the best way to do it is to hook your computer to a receiver. If you play games and you want positional audio you will have to do this by using the analog outs(you will need 3.5 mm -> RCA converters) but if you just want to watch movies in 5.1 and get some better quality sound out of music...just use the digital out(3.5mm(mono or stereo)->RCA needed)
  4. Greg_Hammond
    Greg_Hammond Agent
    Jan 31, 2005
    38
    Hi, Ned -
    Take a look at the Logitech Z-5500 Digital 5.1 kit. It provides a full 5.1 speaker THX-certified solution, with just enough control and features so you're not using your computer to make constant adjustments. Cost about $400.
    You will need a sound card for your computer that has a DIGITAL OUTPUT, or at the very least a sound card with discreet 6-channel analog audio outputs. A decent card for games and basic PC-based home theater is the Creative Labs Audigy2 ZS. Cost about $100.
    If you want to interface your computer with a full-blow home audio/theater system, all you really need is the sound card with the digital output, a cable, and an external A/V receiver - and lots of speakers an speaker wire. *grin*
    Greg
