Compressed ,rar files
Discussion in 'Computers' started by Camp, May 16, 2003.
  1. Camp
    Camp Cinematographer
    Dec 3, 1999
    2,301
    Managing .zip files in WinXp is pretty much a thing of the past as Windows can now open them. However, WinXP doesn't know what to do with .rar files -and .rar seems to be gaining popularity.
    Is there any freeware that can open .rar files? I was using a piece of shareware called PowerZip. I just refuse to pay $20 for a piece of software I'll rarely use.
    Less important to me is to understand why .rar files seem to be more common. Zip files seem to work well and WinXP handles them natively, so why even bother with .rar? Just curious.
  2. John_Berger
    John_Berger Cinematographer
    Nov 1, 2001
    2,489
    RAR will break a large file down to multiple smaller files. It's used (almost) exclusively with newsgroups (Usenet) so that when downloading binaries you can download them a piece at a time rather than restricting yourself to one enormous download that can be lost if your connection drops. New versions of RAR also have CRCs built in to correct any corruption that might have occurred during the download process.
    As you stated, for reasons that defy logic it is gaining populrity for even small file transfers when Zip is the tool that should have been used because of its universal nature.
    Just use a tool like WinRAR or PowerArchiver. Be careful on which version you use. Older versions of PowerArchiver have difficulty reading newer RAR files.
  3. Todd_B
    Todd_B Second Unit
    Jul 16, 2000
    381
    I'll second WinRar...
    Todd B
  4. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Just because something is universal, doesn't mean it's the best solution. Rar is infinately more flexible, has better error recovery, often does a better job of compression, etc. RAR is gaining popularity because it's a better system than zip, and many people (like myself) like to go with a single system for all compresion needs-- you should find this a refreshing idea that something that is BETTER can come along and dethrone a less robust product, even if it has become a standard.
    Winrar is free. Check out http://www.rarsoft.com or http://www.rarlabs.com
  5. John_Berger
    Nov 1, 2001
    2,489
  6. Camp
    Dec 3, 1999
    2,301
    Yea, WinRar is $29.
    Thanks for the info though guys. I guess it's nice having the error correction. Sure wish WinXP could decompress .rar's without a helper app though.
    I did find a free .rar application. It's called "ExtractNow". Here's a link: http://nmoin.brinkster.net/en/
  7. Patrick Larkin
    Patrick Larkin Screenwriter
    May 8, 2001
    1,759
    Stuffit Expander will open most anything including .rar. and it works on Windows, Mac, Linux, and Solaris. Oh, and its free on Mac and Windows.
    .sit, .zip, .tar, .gzip etc.
    http://www.stuffit.com/expander/
  8. John_Berger
    Nov 1, 2001
    2,489
    WOW! Even Solaris? That's very cool!
    And I thought that Stuffit was only for Macs! Time to download!
  9. Andy Olivera
    Andy Olivera Screenwriter
    Jul 25, 2000
    1,303
    I'll second Vince's recommendation of RAR over ZIP. ZIP is universal, but RAR almost always compresses better than ZIP. When I'm about to upload something, I always run both. If the difference is small, I'll go with ZIP, but I've had numerous RAR archives that compress %5+ better.
    Another plus, aside from RAR's error recovery, is that it can handle huge files, while I believe ZIP is limited to 2GB. It's good for backups... [​IMG]
  10. Kolya
    Kolya Stunt Coordinator
    Mar 10, 2001
    91
    I switched from WinZip to WinRAR about three years ago because of the better compression and better explorer integration. In fact, I never use WinRARs interface directly.
    To create, I just select the files, right-click, and select "Add to archive...".
    Extraction is just a right-click away. WinRar is smart enough to guess the next volume name, whether the set is named file.00x or file.partx.rar
    I also like the ability to see the archive details on a tab next to the file properties.
    One more thing: WinRAR can extract most self-extracting installers, so you can inspect the files contained before installing the program.
    I guess I should reg it one of these days :b
