RussellTodd
- May 17, 2004
Can anyone tell me what the difference would be if you use the componet cables running from my cable box instead of just running the coax cable. I run componet left and right audio cables from my cable box directly into my receiver. However is the signal quality on the video any better using the yellow cable to the VCR and then to the TV or is it just the same using the coax. I can't realy tell the difference but I might not know what to look for.
