Rick Wilson
- Aug 1, 2002
My new 65909 will be delivered next week. Due to the layout of my greatroom, it will have to go diagonally across a corner of the room. There is a window and door on the left side and fireplace on the right. Therefore, my components (A/V receiver, VCR, DVD, DirecTV box, and center channel speaker) will have to go on top. I would like to help spread out some of the weight. I have 3 ideas so far:
1. a 3/8 inch piece of glass laid on that spongy shelf liner and would hopefully disperse the weight evenly across the top of the set.
2. a 1/2 inch sheet of birch plywood with a 1X2 strip all around the edge (would be under the plywood and raise the plywood 1 inch - ie. 2 inch footprint). This would be laminated in a complimentary laminate (wife factor). This would distribute the weight around the edges of the top.
3. Laminate a 1/2 inch or 3/4 inch board and lay it on top without any feet.
Which of these would be better? Is there another possibility? I can not use a component stand.
Which idea would be best
