Component Video Cables for DLP TV
Discussion in 'Beginners, General Questions' started by Drew_S, Jan 15, 2004.
  1. Drew_S
    Drew_S Auditioning
    Jan 14, 2004
    2
    I just Purchased a Samsung DLP 50" HDTV. The Video component cables that I am currently using are the ones that the cable company supplied. Is there a need to go out and spend some money on better cables or just use the ones that I have? The picture is already pretty good. If so let me know who makes the best cables. I have seen Monster and Acoustic Research at the stores. Is there a big difference in the two brands, or should I go with a company that makes their own?
  2. Jerry Parker
    Jerry Parker Stunt Coordinator
    Jan 15, 2001
    174
    The ones you have currently should work just fine.
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Hi Drew. Welcome to HTF!
    Usually the supplied cables are .. so so quality.
    While I am not a fan of expensive copper, I do believe you should buy cables designed for the frequencies you intend to push and the size of the display.
    This link to What cables should I buy gives you a quick overview on cables and some recomendations.
    Hope it helps.
