HermannMasser
- Sep 12, 2003
Hi,
I have read many different opinions as to what is the minimum bandwidth rating on a component video Switch to pass HDTV signals, I was looking at the JX-S111 and found it only "passes" 30MHz and then I read different and contraicting opinions as to what is enough to pass HDTV signals, My questions are:
1.- Would the JX-S111 would still pass an HDTV signal and what would be the effect knowing that it is rated at 30MHz? (i.e. degradation, etc)
2.- What would be the minimum bandwidth that I look for on a component switch to ensure a good signal is passed?
An alternative to the JX-S111 would be to get a new receiver and I found several units that would go from 50MHZ up to 80MHZ on component switching but I don't know if it is really worth the extra $$$$, also, along the same lines, I figured that If I get a good quality Component Switch and a decent AV switch (for my S-Video Signals)I would come very very close to buying a new receiver ($$$)....
Any input would be greatly appreciated.
FYI, I am using an Infocus X1 projector (2000:1 contrast ratio) on a 100" 4:3 screen, and unless the room is dark I can't really appreciate or notice any difference in signal quality, I only use my projector after it is dark....
Hermann
Hermann
