Component Video 30' Run (1 Viewer)
I will be receiving my RPTV and DVD player soon. The setup will require 30' component video cables. I am looking for reasonably priced cables that will do a proper job. The lowest quote so far has been about $200 CDN or approx. $130 U.S.
Any recommendations?
Mark Rich
There are a lot of reasonable priced high performance cables available. For a lot less than what you have been looking at as well.
Try either RhinoCables.com or Bluejeancable.com Both sell a 30ft set for around $70.00 U.S.
They use belden 1694a with Canare connectors. Highly recomended on a lot of on-line forums.
Rhinocables is in Canada so you may want to start there. If you look in their link section they also list some other on-line cable makers that may be worth checking out.
NHCondon
