Component Vid Switcher (1 Viewer)
Brian Schucher
Selling a perfect AV TOOLBOX Model 5842 remote controlled component video and audio switcher.
AVT-5842 Component Video Routing Switcher
AVT-5842 Component Video Router is a 4-Input by 2-Output switcher that can be used for either YPbPr Progressive Scan Video or YCbCr Component Video, plus Stereo Audio. The AVT-5842 is Dual Output Switcher and the selected input is routed to both outputs. Selection can be made by the front panel push buttons or by the IR Remote Control. Up to four devices with Component Video outputs, such as DVD Players, Video Game Consoles, HDTV Receivers or HD Cable Boxes, can be connected to two TV Sets, HDTV Displays or other devices with Component Video inputs, without moving cables around. The high signal bandwidth insures no loss of video or audio quality. Note - This unit does not transcode, so for example, a YPbPr input signal cannot go to a YCbCr device.
AVT-5842 Features and Specs
4 Component Video Inputs via RCA connectors
4Ê Stereo Audio Inputs via RCA connectors
2 Component Video Outputs via RCA connectors
Works with Progressive Scan YPbPr 480p, 576p, 720p or 1080i Component Video
Works with Interlaced Scan YCbCr Component Video
IR Remote or Manual Control
Video Bandwidth: 100MHz
Channel Separation: >50dB
Noise Reduction: >50dB
NTSC and PAL compatible
Size: 1.9" High x 9" Wide x 5.7" Deep (48 x 230 x 145mm)
Weight: 2 lbs (920g)
12VDC @ 185mA Power Consumption
115VAC Power Adapter Included
Retails for 119.00
Selling for 75.00 Paypal preferred.. Thanks
JoeyT66
