Component used for coaxial cable
Discussion in 'Accessories, Cables, and Remotes' started by nathan cashman, Aug 29, 2005.
  1. nathan cashman
    nathan cashman Auditioning
    Aug 12, 2005
    7
    I am using a single high quality component cable in place of a coax cable from my DVD player to my receiver.
    Would I be losing any sound quality via this method or is my component cable plugged into the digital coaxial connections doing exactly the same thing with no loss of sound quality?
    Thanks, nc
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Well, if you're not hearing any dropouts, you're good to go. The cable ought to be 75 ohm which you can check by consulting the manufacturer, but there are even times when one can use a coat hanger with complete success.
  3. nathan cashman
    Aug 12, 2005
    7
    Thanks Chu, I'll save my money on digital coax cable and put it into something more worthwhile.
    nc
