Component to RGB 15pin converter? Help!
Discussion in 'Archived Threads 2001-2004' started by Doug_H, Nov 15, 2001.
  1. Doug_H
    Doug_H Supporting Actor
    Mar 21, 2000
    586
    I have found several listed but nobody has any in stock nor do they know when they will have any. If you know of someone who might have one in stock please let me know where.
    The Mischievous Rogue Strikes Again! The Humble Hanson Theater
  2. Doug_H
    Mar 21, 2000
    586
    I can't be the only one with a projector that needs a 15 pin RGB to accept progressive scan. What are you guys using to convert the signal?
  3. CaspianM
    CaspianM Stunt Coordinator
    Oct 4, 2000
    87
  4. Greg Risley
    Greg Risley Second Unit
    Sep 21, 1998
    288
    Hey Doug,
    What projector do you have? Do you need a converter or just a breakout cable? If you just need a breakout. Try Altex up on the northside off 35. I was there the other night and they had 4 different lengths. The cable is actually a VGA 15pin to a 5 BNC connectors. You only have to use the red, blue, and green, so pickup 3 BNC to RCA adapters. I did this for LT150 and it does great.
    [Edited last by Greg Risley on November 17, 2001 at 01:24 AM]
  5. Dennis Nicholls
    Dennis Nicholls Lead Actor
    Oct 5, 1998
    9,106
    388
    9,110
    Boise, ID
    Dennis
    The other manufacturer of a YPrPb to VGA converter is Audio Authority www.audioauthority.com . I purchased both the Key Digital and the Audio Authority and prefer the AA for use with a progressive scan DVD player (Tosh 6200) with my Marquee 8501LC.
  6. errol
    errol Stunt Coordinator
    Dec 29, 1999
    150
    Hi Doug,
    Looks like you have a Tosh. You indeed will need a transcoder. You can get them the sources above. Another source is copperbox which sells the key digital, audio authority, and the rca. You may want to try digitalhome and medical video systems.
    Errol
