Chris PG
- Aug 7, 2003
Hello all. I've known about this site for the longest time, but have never had to use it, until now. I'm glad to be aboard.
For my first post here, I have question about a component switcher box that I saw.
I have an Xbox, dvd player and a HDTV cable box that needs to be hooked up to my HDTV which only has two component inputs. I have seen two items that will resolve this problem, both do the exact same thing(or so I think), but one is much cheaper than the other.
EDIT
I just found out that I cannot post any URL's as of yet. I've had to take away my links to the websites I wanted people to see. Now you will have no clue to what I'm trying to ask of the board unless you search for it yourself.
EDIT
Here is the first one that was recommended to me. It's made by JVC and it's a component switcher. It was found at the etronics.com website, product # JX-S111.
Here is the second one which is located at the Madcatz.com website. It's under the "universal accessories" and it's called a HDTV component switcher.
The first one is a JVC model which retails anywhere from $75-$100, depending where you look. The second, manufactured by Madcatz, retails between $30-$40, again depending where you look. On paper, they look to be the exact same and function the same way. At least that's what I'm hoping.
My question for the board is, do you think that the Madcatz product supports a true HD signal like the JVC does? I had e-mailed their tech support two days ago asking this very same question and have yet to hear a response from them.
I'm leaning more towards a yes(it does support a HD signal) because it clearly states that it is a HDTV component switcher. I'm just a little hesitant about it until I have a definitive answer. I have asked on other boards and some say yes, while others say no.
Thanks for your input and help guys.
EDIT
EDIT
