Component Switch Question
Discussion in 'AV Receivers' started by Mike<> C, Jan 7, 2006.
  1. Mike<> C
    Mike<> C Stunt Coordinator
    May 8, 2005
    96
    Just got on this bandwagon recently becouse I upgraded to Tivo with only 1 composite and 1 s video in on my tv, so now everything goes into my Harman Kardon AVR 120 out to my tv the problem Im having now is my reciever keeps shutting down, Is there something Im missing? Is there a better HK that will do what I want?
  2. Steve_Blazer
    Steve_Blazer Stunt Coordinator
    Nov 29, 2003
    55
    What situation is making it shut down?
    More info would help.
  3. Mike<> C
    May 8, 2005
    96
    For instance my Tivo is connected to the input on Video one of the reciever using Svideo and Copmposite audio then S video on Monitor out to tv so when I press Video 1 to turn all those on it comes on for a few seconds then shuts off.
    Ive been playing around a bit and when I reset the processor it works for awhile but then starts up again.
  4. Mike<> C
    May 8, 2005
    96
    *Update*
    my rear speakers recently were cut but the leads were still connected to the receiver therefore shorting the processor which is a failsafe on HK,I disconnected the speakers and tested seems to work fine so far will keep updated!
  5. gene c
    gene c Producer
    Aug 5, 2003
    5,850
    51
    9,110
    Bay area, Ca
    Gene
    H/K's internal circuit protection is very sensitive. Watch those connections. No frayed, dis-connected or loose wires. Glad it seems to be working now.
  6. Mike<> C
    May 8, 2005
    96
