Component Rack (1 Viewer)
Tom Scholfield
Hi,
Anyone have any advice for building a nice component rack from say a hardware store like home depot. Any words of wisdom would be greatly aprecieated.
KyleGS
I built a tv stand/component holder from all wood. Really cheap, strong and looks pretty good. I got everything at Lowe's.
Pic1
pic2
Jeffrey Noel
Kyle, what size of D-series tv is that? I have a set-up quite like yours. 32" jvc D-series tv, jbl s-center, and 4 jbl s26s.
What type of wood did you use? Is that just white pine stained?
Mike Matheson
If you haven't, try searching the forum for "flexy" or "flexi"--lots of ideas on a flexy rack. Probably something in the archive as well.
You might need to run to several Home Depots before finding enough straight, clean all-thread rods.
I used hose gaskets instead of neoprene washers for spacers between the shelf and washers. Hose gaskets are about $3 per 50 (100?) I think, while neoprene gaskets can be $.59 each. . .
KyleGS
Its the 32" JVC- very good set for the money IMO. I just used the pine planks at Lowes'. Again pretty good stuff for the money :) and turned out to look good for pine.
Allen Ross
yup i am def going to build a small one this weekend, 2 feet wide by 18 deep by three feet high with two shelves and i will put my microwave (mmm dorm room) bfd and books in it. i won't have time to finish it though.
Bosshoag
