Component Cables Made Picture Fuzzy
Discussion in 'Accessories, Cables, and Remotes' started by KennyG, Jan 12, 2004.
  1. KennyG
    KennyG Extra
    Feb 10, 2003
    24
    I recently purchased a component cable. After plugging in and setting my DVD player to progressive mode, I am wondering why the picture looked fuzzy. I thought the component cable was supposed to make the picture better?
    I have a Pioneer 563a, Onkyo 501 receiver (no video cables through the receiver though) and a Hitachi 32 UDX 10 S TV.
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Might be the change to progressive- some people find the doubler in their TV set to do a better job than a cheaper progressive scan dvd player.
    Did you try the same cables in interlaced mode?
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    If you dont mind my asking, what brand/model/price of component cable did you buy?
    You may have a bad cable, or a low-end cable that was designed to handle standard component video (480i = 4 Mhz max. 480p = 13 Mhz max).
    The other common problem is loose-connectors. Are they snug?
    Vince had a great suggestion - try Interlace mode. If you still have fuzzy picture with interlace, likely the cable is defective.
  4. KennyG
    KennyG Extra
    Feb 10, 2003
    24
    I bought a 2 meter AR cable from Best Buy for around $20. I don't have the money to go with better cables route right now. They do fit snug though, I had a problem trying to push them in to connect to the TV! I'll see if I can choose interlace mode with those cables. Thanks.
  5. Bob McElfresh
    May 22, 1999
    5,182
    The AR Pro2 line of cables are quite good for the $$, but I thought they ran about $35. So you may have bought the standard-grade cables. These work OK, but... I really cannot say they were designed for progressive video.
