Component cables for PS2
Discussion in 'Archived Threads 2001-2004' started by John-Miles, Jul 2, 2002.
  1. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,216
    3
    110
    Is it worthwhile to buy a component cable for my PS2? the output line on the PS2 is the same whether its an rf modulator, composite or component on the other end. is this a factor? or would the picture be roughly the same quality from the component and composite?
    I understand the differences between component and composite, but with regards to the PS2 specifically i am concerned that this difference may not be as great. any first hand experience people have ahd with this would be great.
    Cheers
  2. Ryan Hammond
    Ryan Hammond Auditioning
    Dec 28, 2001
    7
    I personally upgraded to the S-video PS2 cable (my receiver doesn't have component) and the difference over composite was quite noticeable. I'm sure the component cable will offer even a slightly better picture than the s-video. Make sure you get a decent cable (I bought the one manuf. by Sony), b/c there are some really cheap knockoff companies out there that make ps2 parts (controllers, cables, etc.)
  3. John-Miles
    Nov 29, 2001
    1,216
    3
    110
    Great thanks guy, I figured that was the response i would get but I just had to make sure, sure its only 35 dollars canadian, but well hey im spending everything i got on the Toshiba 36-hfx71 SWEEEEEET [​IMG] god bless toshiba and their awesome products.
    Cheers
    P.S thnaks again.
  4. Josh Lowe
    Josh Lowe Screenwriter
    Jun 19, 2002
    1,063
    I found the picture was sharper using component cables with my PS2 than S-Video was.
  5. Joey Helmsley
    Joey Helmsley Auditioning
    Jun 7, 2002
    6
    I would get the component cables if you have a HDTV, because SOCOM Navy Seals and Tekken 4 both support 480p.
  6. John-Miles
    Nov 29, 2001
    1,216
    3
    110
    I thought the PS2 didn't do progressive scan (as far as I understand it 480p means 480 lines progressively scanned right?)
  7. dave_brogli
    dave_brogli Screenwriter
    Mar 30, 2002
    1,021
    Get the components for socom and tekken...... otherwise there isnt a HUGe difference. This fall when socom and tekken 4 come out we will finally have our 480P!!!! AND NO this is NOT A RUMOR.. THESE ARE CONFIRMED 480P!!!!!
