Tony Mc
- Jan 27, 2002
Quick question... unfortunately the component cable from my DVD player to my projector is about 6 - 10 inches too short. I've run the cable above the drop-down ceiling in my basement to shorten the length which I thought 20 feet of cable would be enough.
I wanted to know if using female couplers to another short set of component cables will be fine to use. Will the picture quality degrade at all? The cables I bought are from Ram Electronics (a sponsor here).
Tony
Tony
