Component Cable Question
Discussion in 'Accessories, Cables, and Remotes' started by Ivan P, Jun 14, 2004.
  1. Ivan P
    Ivan P Stunt Coordinator
    Apr 4, 2004
    62
    I am looking for 2 or 3 (not sure yet) sets of component cables 1m and 2m.
    Right now I have 2 sets of Monster Video 3 Component cables, Monster are good but I still believe are overprice.
    So could you recomend component cables, good and not so expensive.
    Ivan
  2. Brian L
    Brian L Cinematographer
    Jul 8, 1998
    2,969
    39
    1,610
    Let my start by saying that I tend to think most cable claims are B.S., and I personally focus on build quality.
    I recently needed a 4 foot component cable, and bought from Blue Jean Cables (they advertise here). Very, very good build quality.
    They are pretty much priced in the same neighborhood as Radio Shack Gold, and use industry standard components (Canare connectors, Belden cable).
    A totally non-voodoo cable company.
    BGL
  3. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    go to accessories4less.com and check out there cables...the pro series AR has is very good
  4. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    If you already own them and they're not broken what is the point?
  5. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    1. buy some of the ar brand from bb - they're nice quality and about half the price of monster.
    2. have someone switch out the cables but not tell you which ones you're watching. or do an a/b comparison if your gear will allow it.
    3. see if you notice a difference or not.... [​IMG]
  6. Ivan P
    Apr 4, 2004
    62
    The point is that I need 2 or 3 more sets, I am saying I will return or just change Monster I just need more and I don't think Monster worth it $100 per set.
    Ivan
  7. Ryan Leemhuis
    Oct 1, 2002
    490
    trust me just go to accessories4less.com....price for AR is AMAZING
  8. Ivan P
    Apr 4, 2004
    62
    I am already there [​IMG]))
    Just finishing my shopping, I might get more then I need I just can't pass some cables [​IMG]))
