component/audio cable
Discussion in 'Accessories, Cables, and Remotes' started by Gary Silverman, Jun 14, 2003.
  1. Gary Silverman
    Gary Silverman Stunt Coordinator
    Aug 12, 2000
    121
    Can anyone tell me if there's a cable available in long lengths(50'?) that has component video and 2 audio cables in one bundle, with factory installed ends?
  2. Eric Stuckey
    Eric Stuckey Second Unit
    Mar 24, 1999
    421
    I did a look up for you and both Acoustic Research brand & Monster cable ( http://www.monstercable.com/productPage.asp?pin=1306 )
    Only go as long as 4M or 13.12 ft. You might be able to find a " High end " HT shop and have them special make you a set.Any way if you ran cables that long you will degrade the signal. [​IMG]
  3. Gary Silverman
    Aug 12, 2000
    121
    Okay, then what would I do for a customer who wants to use the second zone on his home theater (Denon 3803 receiver) and be able to use all of his ht components at a tv 20' away. We need to fish up the wall at the ht, across the attic, and down the wall at the second tv.
