Doug_B
- Feb 11, 2001
I have two video cable questions:
1. Does a RGBHV cable set provide noticeably better picture quality than a component cable set for HD signals? This would be for an approx 50 ft cable run to be viewed via a DLP proj onto an 80 inch wide screen. Assume Belden 1695A is used for both.
2. Does a cable set converting BNC terminations to RCA terminations exist?
Reason for these questions.
Going to get a DLP proj soon. Plan on having at least 1 component cable set (for DVD) and 1 S-Video cable (for analog TV). I will likely experiment with OTA HDTV, buying a new set top box in the process (and see if my in-attic antenna is sufficient). I minimally don't mind pre-wiring a second set of component cables versus using component switching between DVD and HDTV and am also considering the add'l expense of a RGBHV cable set instead of a second component set, if there will likely be benefit. Depending on the set top box and proj I get, I may need a BNC-to-HD15 VGA breakout cable(s), which I do know exists. Note that I would like to avoid the add'l $ for a quality 50' DVI solution at this time.
The second question would be a "backout" strategy in case HDTV doesn't work out for me (or I just don't do it) and I find a need to convert the RGBHV to a second set of component with RCA terminations (obviously using just 3 of the 5 cables).
I hope my questions make sense, as high quality video is new territory for me.
Thanks.
Doug
Thanks.
Doug
