Justin.A
- Aug 8, 2004
After getting some feedback from you folks on the forums Im starting to reconsider my HT speaker choices.
Infact, Im even more confused/frustrated by choices than ever before!
My initial idea was to get a Logitech Z680 kit for my new entertainment area (+- 5m x 4m x 2.5m). After speaking to a few ppl, the general concencus was that "multimedia" speaker kits are no where near the quality of audio kits / component systems.
Ok, so thats simple, scratch the "multimedia" kit speaker (even though it has THX etc etc).
Now it gets tricky. Unfortunately I dont have the funds for B&O / McLaren etc high end speakers.
My price range puts me squarely in the high-end consumer "kit" level... that would be your electronics companies like "LG, Sony, Panasonic, Samsung". You know, those grey colour kits with dvd player, and everythings plastic...
The other option is an entry level component set, like those offered by Kenwood and Wharfdale.
The folks at the audio shop have recommended a Kenwood set and Id like to hear your feedback.
The kit includes an AMP and 5 speakers (two which are floor standing and have a "port" at the bottom front). I have a DVD player, so thats not an issue.
The folks also tell me that for a room my size a sub will most probably be overkill, and that these speakers should be sufficient.
Ive saved up a bit and am selling my old Technics SUV500 amp and two Technics SB-LX70 200w 3Way speakers, so hope fully this new Kenwood (etc) will be better???
My questions are:
1) Will the Kenwood (etc) system deliver better quality/performance than the "Samsung type plastic kits"?
2) Will the Kenwood (etc) give better performance than my old Technics set, even though it has a lower Watt rating?
3) Is a sub a "must have"?
Ive included the specs below for info.
Any input will be greatly appreciated!
The model they suggest is the Kenwood "Volcano System" which includes the following:
1x Kenwood V4080 5.1 AMP
100w x5
Dolby Digital/DTS/PLII/ActiveEQ/DSP (5modes)
24bit Crystal DSP
24bit resolution D/A a/D
96kfs 24bit data input
1 Optical in, 2 coax in
2x Kenwood 2Way 4"Bookshelf Speakers
50Watt RMS
8 Ohms
1x Dual 4" Centre Channel
100Watt RMS
8 Ohms
2x 3Way Dual5" Floorstanding
120Watt RMS
8 Ohms
My questions are:
100w x5
24bit Crystal DSP
50Watt RMS
8 Ohms
100Watt RMS
8 Ohms
120Watt RMS
8 Ohms
